이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If it is apparent that there are problems regarding the paper being fed through the printer, replacing the paper roller motor is a possible solution. The paper roller motor controls the paper rollers ability to pull paper into the printer and across the ink cartridges for proper printing.
필요한 것
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Detach the white ribbon cable.
Remove the two 9mm Torx screws on either side of the white bracket.
To reassemble your device, with the addition of a new motor, follow these instructions in reverse order.
다른 7명이 해당 안내서를 완성하였습니다.
