주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If the scans or copies made are not matching the desired document, replacing the scanner glass is a solution to consider. There could be a crack or scratch in the glass affecting the quality of the scanned or copied document.
부품
지정된 부품이 없습니다.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  4. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  6. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  7. Remove one 9mm T10 Torx screw from the back of the printer lid.
    • Remove one 9mm T10 Torx screw from the back of the printer lid.
  8. Press outward on the plastic tab holding the back panel in place. Press outward on the plastic tab holding the back panel in place.
    • Press outward on the plastic tab holding the back panel in place.
  9. Pull the back panel towards you and lift it away from the rest of the printer cover. Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
    • Pull the back panel towards you and lift it away from the rest of the printer cover.
    • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
  10. Remove one 9mm T10 Torx screw from the white retaining tab.
    • Remove one 9mm T10 Torx screw from the white retaining tab.
  11. Remove the white retaining tab.
    • Remove the white retaining tab.
  12. To remove the scanner glass, gently push it towards you.
    • To remove the scanner glass, gently push it towards you.
    • Slide glass panel until it is completely removed from printer.
    • Use caution when removing glass and be aware of any sharp edges.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kevin Raives
회원 가입일: 2013년 01월 15일
93 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 1,540
