이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the HP Deskjet fails to produce quality scans or copies, and you have already checked that the scanner glass is clean and that there are no other problems, you may need to replace the Scanner Bar/Light inside the printer. This part is the sensor that illuminates and captures an image of the document you are trying to scan or copy. The steps for removing this part are included in the following guide.
필요한 것
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
