주요 콘텐츠로 건너뛰기
HP Deskjet F4480 Top Lid Replacement
필요한 것
  1. HP Deskjet F4480 Top Lid Replacement, Open front access panel: 1 단계, 이미지 1/1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Top Lid Replacement, Top Lid: 2 단계, 이미지 1/1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Top Lid Replacement: 3 단계, 이미지 1/3 HP Deskjet F4480 Top Lid Replacement: 3 단계, 이미지 2/3 HP Deskjet F4480 Top Lid Replacement: 3 단계, 이미지 3/3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Top Lid Replacement: 4 단계, 이미지 1/2 HP Deskjet F4480 Top Lid Replacement: 4 단계, 이미지 2/2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Top Lid Replacement: 5 단계, 이미지 1/3 HP Deskjet F4480 Top Lid Replacement: 5 단계, 이미지 2/3 HP Deskjet F4480 Top Lid Replacement: 5 단계, 이미지 3/3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
결론
다른 21명이 해당 안내서를 완성하였습니다.
Tim
회원 가입일: 01/15/13
184 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013 회원
CPSU-REGAN-W13S18G35
5 회원들
안내서 15개 작성하였습니다
댓글 한 개
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 9,560
