소개
Replacing the fan is pretty straight-forward, just be sure you have purchased a replacement which is compatible with the ROVE. This guide also has several steps make sure you have suitable places to store all the components and screws you will be removing during the process and of course, good luck!
필요한 것
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 2개
These instructions serve as a guide to battery replacement as well! I forgot to write down the battery replacement part number - anyone have that handy? Thanks!!
I have a problem, my screen doesn't work and it only makes colors and static. I followed the instructions and after assembling it the screen was no longer working
please where can I get the replacement battery
reply to tosinadedeji@gmail.com
tosinwil - 답글
