주요 콘텐츠로 건너뛰기
HP ENVY Rove 20-k014us USB Board Replacement
필요한 것
  1. HP ENVY Rove 20-k014us USB Board Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Working on your device while it’s turned on is potentially dangerous and can result in electrical shock. Please make sure your device is completely turned off before you begin disassembling it.
    • Flip the device over so the screen is face down.
    • Make sure the stand is flipped down for the easiest way to work with the device.
    • Make sure that you put the screen on a clean surface to avoid scratching it.
  2. HP ENVY Rove 20-k014us USB Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the SD card in the bottom of the computer by pressing the SD card in, and it will pop out.
    • Pull out the SD card completely and set aside.
    • If you have never put in an SD card into this slot, a dummy one will be there in the slot.
  3. HP ENVY Rove 20-k014us USB Board Replacement: 3 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two rubber screw covers on the bottom of the plastic cover using the plastic opening tool.
    • Unscrew the two 6.35 mm PH#1 screws that were underneath the rubber covers.
    • The screws cannot be removed, they just unscrew from the interior components of the computer.
  4. HP ENVY Rove 20-k014us USB Board Replacement: 4 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool along the outer rim of the bottom portion of the back panel.
    • Take off this portion.
    • Removing the cover for the first time requires a bit of force. Use the plastic opening tool to get as much separation as possible before you pull off the cover to help prevent it from cracking.
  5. HP ENVY Rove 20-k014us USB Board Replacement: 5 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 5 단계, 이미지 2개 중 2개
    • Remove three 6.35 mm screw from the back panel using a PH#2 or J1 screw driver.
    • Unscrew the two 6.35 mm PH#2 screws. They aren't able to be completely removed and will just be loosened similar to step 3.
  6. HP ENVY Rove 20-k014us USB Board Replacement: 6 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 6 단계, 이미지 2개 중 2개
    • Release the stand by pressing the large button on the left so that it is easier to take the back case off.
  7. HP ENVY Rove 20-k014us USB Board Replacement: 7 단계, 이미지 3개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 7 단계, 이미지 3개 중 2개 HP ENVY Rove 20-k014us USB Board Replacement: 7 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to separate the silver back cover from the screen body.
    • As shown in picture two, use the tool around the stand as well to avoid cracking the cover.
    • As with the bottom cover, removing the top cover requires some force. Using the plastic opening tool to get as much separation as possible will make your job easier in the long run.
  8. HP ENVY Rove 20-k014us USB Board Replacement: 8 단계, 이미지 1개 중 1개
    • Slowly apply pressure to the outsides of the cover until it pops out of place.
    • Carefully lift the cover away from the computer and untangle it from the stand.
    • When putting the back cover back on, make sure you put the bottom of the cover on first so that the plastic cover sits tightly underneath the bottom of the stand case. Then make sure all the plastic tabs are fully pushed in.
    • Make sure that the power button is aligned when you put the back cover on.
  9. HP ENVY Rove 20-k014us USB Board Replacement: 9 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement: 9 단계, 이미지 2개 중 2개
    • Before working on any of the internal components of the computer, make sure the battery is disconnected so there's no power running through the device.
    • Disconnect the battery by using a plastic opening tool and taking the cable connection out.
  10. HP ENVY Rove 20-k014us USB Board Replacement, USB Board: 10 단계, 이미지 2개 중 1개 HP ENVY Rove 20-k014us USB Board Replacement, USB Board: 10 단계, 이미지 2개 중 2개
    • Flip up the white plastic that holds the cable connection using the plastic opening tool.
  11. HP ENVY Rove 20-k014us USB Board Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull out the cable connection.
    • When you insert the cable connection back in, make sure the component is securely fastened.
  12. HP ENVY Rove 20-k014us USB Board Replacement: 12 단계, 이미지 1개 중 1개
    • Remove two 6.35 mm PH#0 screws around the board.
  13. HP ENVY Rove 20-k014us USB Board Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Berit Bingham
회원 가입일: 10/06/15
1,497 평판
안내서 8개를 작성함
Cal Poly, Team 4-4, Maness Fall 2015 Cal Poly, Team 4-4, Maness Fall 2015 회원
CPSU-MANESS-F15S4G4
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 685
