주요 콘텐츠로 건너뛰기
HP Elite X2 1013 G3 Motherboard Replacement
필요한 것
  1. HP Elite X2 1013 G3 Motherboard Replacement, Screen: 1 단계, 이미지 1/1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Motherboard Replacement: 2 단계, 이미지 1/2 HP Elite X2 1013 G3 Motherboard Replacement: 2 단계, 이미지 2/2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Motherboard Replacement: 3 단계, 이미지 1/2 HP Elite X2 1013 G3 Motherboard Replacement: 3 단계, 이미지 2/2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Motherboard Replacement: 4 단계, 이미지 1/2 HP Elite X2 1013 G3 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Motherboard Replacement, Battery: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove five screws from the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink from the tablet.
  8. HP Elite X2 1013 G3 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the single screw from the lightning cable connector using a Phillips #0 screwdriver.
    • Lift the lightning cable connector out of the tablet.
  9. HP Elite X2 1013 G3 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the ten screws holding down the motherboard using a Phillips #0 screwdriver.
  10. HP Elite X2 1013 G3 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard from the tablet.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 24
전체 시간: 563
