주요 콘텐츠로 건너뛰기
HP Elite X2 1013 G3 Solid State Drive Replacement
필요한 것
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: 1 단계, 이미지 1/1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: 2 단계, 이미지 1/2 HP Elite X2 1013 G3 Solid State Drive Replacement: 2 단계, 이미지 2/2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: 3 단계, 이미지 1/2 HP Elite X2 1013 G3 Solid State Drive Replacement: 3 단계, 이미지 2/2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: 4 단계, 이미지 1/2 HP Elite X2 1013 G3 Solid State Drive Replacement: 4 단계, 이미지 2/2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: 7 단계, 이미지 1/1
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: 8 단계, 이미지 1/1
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kory Haydon
회원 가입일: 04/18/19
259 평판
안내서 2개 작성하였습니다
Cal Poly, Team S9-G12, Maness Spring 2019 Cal Poly, Team S9-G12, Maness Spring 2019 회원
CPSU-MANESS-S19S9G12
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 75
전체 시간: 2,728
