소개
When your device isn’t properly loading files, the storage may be the issue. This guide will teach you how to replace the SSD in your device.
필요한 것
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
다른 한 분이 해당 안내서를 완성하였습니다.
