소개
If your device cannot access or recognize your Wi-Fi networks, the wireless card may be faulty. This guide will show you how to replace the wireless card in your device.
필요한 것
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
댓글 한 개
Just to note, this is the WWAN (cellular/LTE) card, not the WLAN card (WiFi). The WLAN card is soldered down and not removable.
