주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Battery Replacement
필요한 것
  1. HP Elite x2 1012 G2 Battery Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Battery Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Battery Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Battery Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Battery Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Battery Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Battery Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Battery Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Battery Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Battery Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Battery Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Battery Replacement, Battery: 7 단계, 이미지 1/1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Battery Replacement: 8 단계, 이미지 1/2 HP Elite x2 1012 G2 Battery Replacement: 8 단계, 이미지 2/2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Battery Replacement: 9 단계, 이미지 1/2 HP Elite x2 1012 G2 Battery Replacement: 9 단계, 이미지 2/2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Battery Replacement: 10 단계, 이미지 1/1
    • Lift the battery out of the device.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Andy Velazquez
회원 가입일: 04/18/18
314 평판
안내서 1개 작성함
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개 작성하였습니다
댓글 4개
how do you test the battery? what voltage should it be maintaining?
scott kay - 답글
Hi, after the replacement battery
toch not working, help pls?
Parsa Aghabeikzadeh - 답글
PC not coming on, also not charging.
Abiola - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 95
30일 전: 427
전체 시간: 22,243
