주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Cooling Fan Replacement
필요한 것
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Cooling Fan Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Cooling Fan Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Cooling Fan Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Cooling Fan Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: 7 단계, 이미지 1/1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: 8 단계, 이미지 1/2 HP Elite x2 1012 G2 Cooling Fan Replacement: 8 단계, 이미지 2/2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: 9 단계, 이미지 1/2 HP Elite x2 1012 G2 Cooling Fan Replacement: 9 단계, 이미지 2/2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: 10 단계, 이미지 1/1
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: 11 단계, 이미지 1/1
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: 12 단계, 이미지 1/2 HP Elite x2 1012 G2 Cooling Fan Replacement: 12 단계, 이미지 2/2
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: 13 단계, 이미지 1/1
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: 14 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: 15 단계, 이미지 1/1
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: 16 단계, 이미지 1/1
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
WesleyEagleson
회원 가입일: 04/06/19
431 평판
안내서 3개 작성하였습니다
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 회원
IUPUI-WILSON-S19S13G13
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 48
전체 시간: 2,360
