메인 컨텐츠로 가기
소개
The front-facing camera is an important of any modern tablet or laptop . This guide shows how to replace a broken or malfunctioning webcam on the HP Elite x2 1012 G2.
  1. Make sure the device is turned off before starting.
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. Remove the six 3mm Torx T5 screws underneath the kickstand. Remove the six 3mm Torx T5 screws underneath the kickstand. Remove the six 3mm Torx T5 screws underneath the kickstand.
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. Turn the device over so the screen is facing you. Place a suction cup firmly onto a corner of the screen.
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. Lift the screen up and off of the device.
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  6. Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently. Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently. Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  7. Remove the screen by gently lifting it off of the device. Remove the screen by gently lifting it off of the device.
    • Remove the screen by gently lifting it off of the device.
  8. Orient the device so that the battery is closest to you.
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  9. Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back. Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back. Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back.
    • Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back.
  10. Remove the connector immediately to the left of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
    • Remove the connector immediately to the left of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  11. Remove the connector immediately to the right of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
    • Remove the connector immediately to the right of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  12. Use a Phillips screwdriver to remove the  Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw. Use a Phillips screwdriver to remove the  Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw.
    • Use a Phillips screwdriver to remove the Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw.
  13. Remove the webcam using a plastic opening tool to lift it up and off.
    • Remove the webcam using a plastic opening tool to lift it up and off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Noah Stapp
회원 가입일: 2018년 04월 18일
482 Reputation
안내서 2개 작성하였습니다
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 18
All Time: 319
