주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Rear Facing Camera Replacement
필요한 것
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 1/2 HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 2/2
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: 8 단계, 이미지 1/2 HP Elite x2 1012 G2 Rear Facing Camera Replacement: 8 단계, 이미지 2/2
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
결론
WesleyEagleson
회원 가입일: 04/06/19
431 평판
안내서 3개 작성하였습니다
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 회원
IUPUI-WILSON-S19S13G13
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 496
