주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 SSD Replacement
필요한 것
  1. HP Elite x2 1012 G2 SSD Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 SSD Replacement: 2 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 2 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 SSD Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 SSD Replacement: 3 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 SSD Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 SSD Replacement: 5 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 5 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 SSD Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 SSD Replacement: 6 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 SSD Replacement, SSD: 7 단계, 이미지 1개 중 1개
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 SSD Replacement: 8 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the single Phillips M2.0x2.0 screw on the SSD using a Phillips screwdriver. Turn the screwdriver counterclockwise to remove the screw.
  9. HP Elite x2 1012 G2 SSD Replacement: 9 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 SSD Replacement: 9 단계, 이미지 2개 중 2개
    • Gently pull the SSD to the left and up to remove it from the device.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hunter Lane
회원 가입일: 04/18/18
297 평판
안내서 1개를 작성함
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개를 작성함
2가이드 댓글
Vielen Dank für die sehr gute Anleitung. Es hat alles perfekt geklappt.
Das Display selber sitzt zum Teil aber sehr fest im Gehäuse und man muss sich überwinden etwas Kraft anzuwenden.
Sollte man zu fest ziehen (und einem das Display entgegenspringt) besteht ja die Gefahr die filigranen Kabel abzureißen.
Andreas Gerl - 답글
Mein Lüfter läuft ständig. Sollte die Wärmeleitpaste eingetrocknet sein?
Der Experte - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 45
지난 30일: 196
전체 시간: 23,841
