주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Screen Replacement
필요한 것
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Screen Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Screen Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Screen Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Noah Stapp
회원 가입일: 04/18/18
731 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개 작성하였습니다
댓글 5개
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - 답글
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - 답글
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - 답글
The touch stopped working after the replacement. Any suggestions?
el._.msn - 답글
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 23
30일 전: 122
전체 시간: 8,401
