주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Screen Replacement
필요한 것
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the screen by gently lifting it off of the device.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Noah Stapp
회원 가입일: 04/18/18
806 평판
안내서 2개를 작성함
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개를 작성함
5가이드 댓글
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - 답글
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - 답글
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - 답글
The touch stopped working after the replacement. Any suggestions?
el._.msn - 답글
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 26
지난 30일: 102
전체 시간: 10,870
