주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Speakers Replacement
필요한 것
  1. HP Elite x2 1012 G2 Speakers Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Speakers Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Speakers Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Speakers Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Speakers Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Speakers Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Speakers Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Speakers Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Speakers Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Speakers Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Speakers Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Speakers Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Speakers Replacement, Speakers: 7 단계, 이미지 1/1
    • Identify the speaker locations.
  8. HP Elite x2 1012 G2 Speakers Replacement: 8 단계, 이미지 1/2 HP Elite x2 1012 G2 Speakers Replacement: 8 단계, 이미지 2/2
    • Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
    • Gently pull the black and red wire free at the motherboard connector.
  9. HP Elite x2 1012 G2 Speakers Replacement: 9 단계, 이미지 1/3 HP Elite x2 1012 G2 Speakers Replacement: 9 단계, 이미지 2/3 HP Elite x2 1012 G2 Speakers Replacement: 9 단계, 이미지 3/3
    • Use the spudger tool to remove the speakers from the housing.
  10. HP Elite x2 1012 G2 Speakers Replacement: 10 단계, 이미지 1/2 HP Elite x2 1012 G2 Speakers Replacement: 10 단계, 이미지 2/2
    • On the right speaker, the black antena piece must be removed before the speaker can be accessed.
  11. HP Elite x2 1012 G2 Speakers Replacement: 11 단계, 이미지 1/2 HP Elite x2 1012 G2 Speakers Replacement: 11 단계, 이미지 2/2
    • Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
WesleyEagleson
회원 가입일: 04/06/19
431 평판
안내서 3개 작성하였습니다
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019 회원
IUPUI-WILSON-S19S13G13
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 43
전체 시간: 1,286
