주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Wi-Fi Card Replacement
필요한 것
  1. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Wi-Fi Card: 7 단계, 이미지 1개 중 1개
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 2개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 3개 중 3개
    • Detach the two wire connections on the upper right of the wi-fi card by hand.
  9. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 9 단계, 이미지 2개 중 2개
    • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  10. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 1개 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 10 단계, 이미지 2개 중 2개
    • Slide the wi-fi card out by hand, lifting the card up and out of the device.
    • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nathan Diekema
회원 가입일: 04/18/18
339 평판
안내서 1개를 작성함
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개를 작성함
1가이드 댓글
Hi is it to upgrade the broadband to support 4g lte? Mine unit when inserted 4g data sim card, only can run edge signal. Spec of the broadband is hp hs3210 hspa+
Kenny Liew - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 9
지난 30일: 22
전체 시간: 2,811
