주요 콘텐츠로 건너뛰기
HP Elite x2 1012 G2 Wi-Fi Card Replacement
필요한 것
  1. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 1/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 2/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 3 단계, 이미지 1/2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 4 단계, 이미지 1/1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 1/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 2/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 5 단계, 이미지 3/3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 6 단계, 이미지 1/2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 6 단계, 이미지 2/2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Wi-Fi Card: 7 단계, 이미지 1/1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 1/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 2/3 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 8 단계, 이미지 3/3
    • Detach the two wire connections on the upper right of the wi-fi card by hand.
  9. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 9 단계, 이미지 1/2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 9 단계, 이미지 2/2
    • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  10. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 10 단계, 이미지 1/2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 10 단계, 이미지 2/2
    • Slide the wi-fi card out by hand, lifting the card up and out of the device.
    • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nathan Diekema
회원 가입일: 04/18/18
294 평판
안내서 1개 작성함
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S18G5
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
Hi is it to upgrade the broadband to support 4g lte? Mine unit when inserted 4g data sim card, only can run edge signal. Spec of the broadband is hp hs3210 hspa+
Kenny Liew - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 38
전체 시간: 2,281
