주요 콘텐츠로 건너뛰기
HP Elite x2 G1 1012 Display Replacement
필요한 것
  1. HP Elite x2 G1 1012 Display Replacement, Display: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: 2 단계, 이미지 1/2 HP Elite x2 G1 1012 Display Replacement: 2 단계, 이미지 2/2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: 3 단계, 이미지 1/1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: 4 단계, 이미지 1/2 HP Elite x2 G1 1012 Display Replacement: 4 단계, 이미지 2/2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: 5 단계, 이미지 1/3 HP Elite x2 G1 1012 Display Replacement: 5 단계, 이미지 2/3 HP Elite x2 G1 1012 Display Replacement: 5 단계, 이미지 3/3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: 6 단계, 이미지 1/2 HP Elite x2 G1 1012 Display Replacement: 6 단계, 이미지 2/2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Colin Mika
회원 가입일: 04/19/18
943 평판
안내서 6개 작성하였습니다
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018 회원
CPSU-MANESS-S18S24G7
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 34
전체 시간: 3,275
