주요 콘텐츠로 건너뛰기
HP Elite x2 G1 1012 Motherboard Replacement Guide
필요한 것
  1. HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: 1 단계, 이미지 1/2 HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: 1 단계, 이미지 2/2
    • Detach the keyboard from the screen.
  2. HP Elite x2 G1 1012 Motherboard Replacement Guide: 2 단계, 이미지 1/1
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available when we received our device.
  3. HP Elite x2 G1 1012 Motherboard Replacement Guide: 3 단계, 이미지 1/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 3 단계, 이미지 2/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 3 단계, 이미지 3/3
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Motherboard Replacement Guide: 4 단계, 이미지 1/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 4 단계, 이미지 2/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 4 단계, 이미지 3/3
    • Detach flex cable from motherboard using tweezers.
  5. HP Elite x2 G1 1012 Motherboard Replacement Guide: 5 단계, 이미지 1/1
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Motherboard Replacement Guide: 6 단계, 이미지 1/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 6 단계, 이미지 2/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 6 단계, 이미지 3/3
    • Remove ten 2.7mm screws using the Phillips #0 screwdriver.
  7. HP Elite x2 G1 1012 Motherboard Replacement Guide: 7 단계, 이미지 1/2 HP Elite x2 G1 1012 Motherboard Replacement Guide: 7 단계, 이미지 2/2
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Motherboard Replacement Guide: 8 단계, 이미지 1/2 HP Elite x2 G1 1012 Motherboard Replacement Guide: 8 단계, 이미지 2/2
    • Detach the left speaker.
  9. HP Elite x2 G1 1012 Motherboard Replacement Guide: 9 단계, 이미지 1/2 HP Elite x2 G1 1012 Motherboard Replacement Guide: 9 단계, 이미지 2/2
    • Detach the two stickers highlighted from the right speaker.
  10. HP Elite x2 G1 1012 Motherboard Replacement Guide: 10 단계, 이미지 1/1
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Motherboard Replacement Guide: 11 단계, 이미지 1/2 HP Elite x2 G1 1012 Motherboard Replacement Guide: 11 단계, 이미지 2/2
    • Detach the right speaker.
  12. HP Elite x2 G1 1012 Motherboard Replacement Guide: 12 단계, 이미지 1/1
    • Detach the WWAN card from the motherboard by pulling it to the left using tweezers.
  13. HP Elite x2 G1 1012 Motherboard Replacement Guide: 13 단계, 이미지 1/1
    • Detach the SSD from motherboard by pulling it to the left using tweezers.
  14. HP Elite x2 G1 1012 Motherboard Replacement Guide: 14 단계, 이미지 1/1
    • Use the plastic opening tool to loosen the motherboard.
  15. HP Elite x2 G1 1012 Motherboard Replacement Guide: 15 단계, 이미지 1/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 15 단계, 이미지 2/3 HP Elite x2 G1 1012 Motherboard Replacement Guide: 15 단계, 이미지 3/3
    • Detach the motherboard from the casing.
    • Apply pulling force to the left to pull out the ports from the casing safely.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Hanif Norhisham
회원 가입일: 05/22/19
571 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Harley Summer 2019 IUPUI, Team S1-G5, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S1G5
4 회원들
안내서 2개 작성하였습니다
댓글 한 개
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
Pablo Sánchez-Simón - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 32
전체 시간: 3,188
