주요 콘텐츠로 건너뛰기
HP Elite x2 G1 1012 SSD Card Replacement
필요한 것
  1. HP Elite x2 G1 1012 SSD Card Replacement, Display: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 SSD Card Replacement: 2 단계, 이미지 2개 중 1개 HP Elite x2 G1 1012 SSD Card Replacement: 2 단계, 이미지 2개 중 2개
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 SSD Card Replacement: 3 단계, 이미지 1개 중 1개
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 SSD Card Replacement: 4 단계, 이미지 2개 중 1개 HP Elite x2 G1 1012 SSD Card Replacement: 4 단계, 이미지 2개 중 2개
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 SSD Card Replacement: 5 단계, 이미지 3개 중 1개 HP Elite x2 G1 1012 SSD Card Replacement: 5 단계, 이미지 3개 중 2개 HP Elite x2 G1 1012 SSD Card Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 SSD Card Replacement: 6 단계, 이미지 2개 중 1개 HP Elite x2 G1 1012 SSD Card Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 SSD Card Replacement, SSD Card: 7 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the screw on the left hand side of the card.
  8. HP Elite x2 G1 1012 SSD Card Replacement: 8 단계, 이미지 1개 중 1개
    • Slightly lift the card up and then remove the SSD card from the device.
    • As you slide it out, make sure it gets unplugged from the port. Do not continue to tug on a stuck port.
결론
작성자
2다른 기여자 명과 함께
Colin Mika
회원 가입일: 04/19/18
943 평판
안내서 6개를 작성함
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018 회원
CPSU-MANESS-S18S24G7
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 29
지난 30일: 45
전체 시간: 4,488
