주요 콘텐츠로 건너뛰기
HP Elite x2 G1 1012 Speaker Replacement Guide
필요한 것
  1. HP Elite x2 G1 1012 Speaker Replacement Guide, Speakers: 1 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide, Speakers: 1 단계, 이미지 2/2
    • Detach keyboard from the screen.
  2. HP Elite x2 G1 1012 Speaker Replacement Guide: 2 단계, 이미지 1/1
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available on our device, so we do not know what kind of screwdriver to use.)
  3. HP Elite x2 G1 1012 Speaker Replacement Guide: 3 단계, 이미지 1/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 3 단계, 이미지 2/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 3 단계, 이미지 3/3
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Speaker Replacement Guide: 4 단계, 이미지 1/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 4 단계, 이미지 2/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 4 단계, 이미지 3/3
    • Detach flex cable from motherboard using tweezers.
  5. HP Elite x2 G1 1012 Speaker Replacement Guide: 5 단계, 이미지 1/1
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Speaker Replacement Guide: 6 단계, 이미지 1/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 6 단계, 이미지 2/3 HP Elite x2 G1 1012 Speaker Replacement Guide: 6 단계, 이미지 3/3
    • Remove two 2.7 mm screws using the Phillips #0 screwdriver.
  7. HP Elite x2 G1 1012 Speaker Replacement Guide: 7 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide: 7 단계, 이미지 2/2
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Speaker Replacement Guide: 8 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide: 8 단계, 이미지 2/2
    • Detach the left speakers.
  9. HP Elite x2 G1 1012 Speaker Replacement Guide: 9 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide: 9 단계, 이미지 2/2
    • Detach the two stickers highlighted from right speaker.
  10. HP Elite x2 G1 1012 Speaker Replacement Guide: 10 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide: 10 단계, 이미지 2/2
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Speaker Replacement Guide: 11 단계, 이미지 1/2 HP Elite x2 G1 1012 Speaker Replacement Guide: 11 단계, 이미지 2/2
    • Detach the right speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hanif Norhisham
회원 가입일: 05/22/19
564 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G5, Harley Summer 2019 IUPUI, Team S1-G5, Harley Summer 2019 회원
IUPUI-HARLEY-SU19S1G5
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 666
