주요 콘텐츠로 건너뛰기
HP Elite x2 G4 Battery Replacement
필요한 것
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: 1 단계, 이미지 1/1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: 2 단계, 이미지 1/1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: 3 단계, 이미지 1/1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: 6 단계, 이미지 1/1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: 7 단계, 이미지 1/1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: 8 단계, 이미지 1/1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Goncalo Felix
회원 가입일: 10/25/22
325 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G4
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 24
30일 전: 138
전체 시간: 1,221
