주요 콘텐츠로 건너뛰기
HP Elite x2 G4 Motherboard Replacement
필요한 것
  1. HP Elite x2 G4 Motherboard Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Motherboard Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the two 2.5 mm Phillips #0 screws that secure the USB bracket to the motherboard.
  7. HP Elite x2 G4 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the USB bracket off of the motherboard and remove it.
    • Remove the four 2 mm Phillips #0 screws that secure the motherboard.
  8. HP Elite x2 G4 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • You would then disconnect the following cables from the motherboard:
    • - Left and right speaker cables.
    • - Volume button board ribbon cable.
    • - Left and right hall sensor ribbon cables.
    • - Fingerprint reader ribbon cable.
    • - WLAN antenas.
    • - SIM cardboard ribbon cable.
    • - POGO ribbon cable.
  9. HP Elite x2 G4 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Slide the external connectors out of the cutout in the display enclosure and remove.
    • Do not remove the BIOS board from the motherboard. The motherboard must be returned with the BIOS board attached.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Goncalo Felix
회원 가입일: 10/25/22
325 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G4
5 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 40
전체 시간: 881
