주요 콘텐츠로 건너뛰기
HP EliteBook 1040 G4 Motherboard Replacement
필요한 것
  1. HP EliteBook 1040 G4 Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Motherboard Replacement, SSD: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw securing the SSD to the motherboard.
  7. HP EliteBook 1040 G4 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the SSD up and out of the device.
  8. HP EliteBook 1040 G4 Motherboard Replacement, Fan: 8 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement, Fan: 8 단계, 이미지 2개 중 2개
    • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
    • The top left screw may be hidden under shielding tape.
  9. HP EliteBook 1040 G4 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 HP EliteBook 1040 G4 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the electrical tape to expose the heat sink screws.
    • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
    • Carefully disconnect the pin connector by pulling it from its slot.
  10. HP EliteBook 1040 G4 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully remove the wires from the clip to the left of the fan.
  11. HP EliteBook 1040 G4 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Lift and remove the fan and heatsink assembly from the device.
  12. HP EliteBook 1040 G4 Motherboard Replacement, Motherboard: 12 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the five black 4 mm screws securing the motherboard to the device.
  13. HP EliteBook 1040 G4 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Using the same Phillips #0 screwdriver, remove the two silver 6.5 mm screws from the secondary fan placeholder.
    • Remove the fan placeholder from the device.
  14. HP EliteBook 1040 G4 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Carefully disonnect the "Main" and "Aux" cables from the dual band wireless driver.
  15. HP EliteBook 1040 G4 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the ZIF connector from the bottom left of the motherboard by lifting the small grey tab, then pulling the connector out of the slot.
    • For more information on properly disconnecting and removing Zero Insertion Force (ZIF) connectors, please visit this guide.
  16. HP EliteBook 1040 G4 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Disconnect and remove the four ZIF connectors from the bottom middle of the motherboard by lifting the small locking tabs, then pulling the connectors out of their slots.
  17. HP EliteBook 1040 G4 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the pin connector from the top right corner of the motherboard.
  18. HP EliteBook 1040 G4 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the ZIF connector from the top right corner of the motherboard by lifting the locking tab, then pulling the connector out of the slot.
  19. HP EliteBook 1040 G4 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Remove the pin connectors in the top right corner of the motherboard by lifting them straight up. The longer, top, connector has a pull tab connected to it to assist in pulling it out.
  20. HP EliteBook 1040 G4 Motherboard Replacement: 20 단계, 이미지 3개 중 1개 HP EliteBook 1040 G4 Motherboard Replacement: 20 단계, 이미지 3개 중 2개 HP EliteBook 1040 G4 Motherboard Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the RTC battery pin connector from the underside of the motheroard.
  21. HP EliteBook 1040 G4 Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Carefully lift and remove the motherboard.
결론
작성자
5다른 기여자 명과 함께
Ryan Cameron
회원 가입일: 09/28/21
181 평판
안내서 1개를 작성함
Clemson, Team 4-1, Hunter Fall 2021 Clemson, Team 4-1, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G1
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 21
지난 30일: 48
전체 시간: 1,315
