주요 콘텐츠로 건너뛰기
HP EliteBook 1050 G1 Motherboard Replacement
필요한 것
  1. HP EliteBook 1050 G1 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 HP EliteBook 1050 G1 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 Motherboard Replacement: 2 단계, 이미지 1/3 HP EliteBook 1050 G1 Motherboard Replacement: 2 단계, 이미지 2/3 HP EliteBook 1050 G1 Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
  3. HP EliteBook 1050 G1 Motherboard Replacement: 3 단계, 이미지 1/2 HP EliteBook 1050 G1 Motherboard Replacement: 3 단계, 이미지 2/2
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
  4. HP EliteBook 1050 G1 Motherboard Replacement: 4 단계, 이미지 1/2 HP EliteBook 1050 G1 Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove eight 4.5 mm screws from the battery with a Phillips #1 screwdriver.
    • Disconnect the white tipped battery cable from the motherboard.
  5. HP EliteBook 1050 G1 Motherboard Replacement: 5 단계, 이미지 1/3 HP EliteBook 1050 G1 Motherboard Replacement: 5 단계, 이미지 2/3 HP EliteBook 1050 G1 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the six 4.5mm screws from the fan assembly using a Phillips #00 screwdriver.
    • Unscrew four 3.6mm screws from the heatsink assembly with a Phillips #00 screwdriver.
    • These "captive" screws are connected to the heatsink and will not detach from it.
    • Remove the fan assembly.
  6. HP EliteBook 1050 G1 Motherboard Replacement: 6 단계, 이미지 1/1
    • Unplug the seven ZIF connecters from the motherboard by flipping up the black switches with a spudger and pulling out the cables.
  7. HP EliteBook 1050 G1 Motherboard Replacement: 7 단계, 이미지 1/3 HP EliteBook 1050 G1 Motherboard Replacement: 7 단계, 이미지 2/3 HP EliteBook 1050 G1 Motherboard Replacement: 7 단계, 이미지 3/3
    • Remove two 1.9mm screws from the display cable bracket using a Phillips #00 driver.
    • Remove the two connectors on the right side gently.
    • Remove the connector on right side of motherboard.
    • Remove the three 4.5mm screws using a Phillips #00 driver and remove the bracket.
    • Remove the two coaxial cables.
  8. HP EliteBook 1050 G1 Motherboard Replacement: 8 단계, 이미지 1/2 HP EliteBook 1050 G1 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the two 3mm screws using a Phillips #00 driver.
    • Remove the motherboard by lifting it up and out of the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elijah Holder
회원 가입일: 09/16/20
386 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 27
전체 시간: 533
