주요 콘텐츠로 건너뛰기
HP EliteBook 1050 G1 SSD Replacement
필요한 것
  1. HP EliteBook 1050 G1 SSD Replacement, SSD: 1 단계, 이미지 1/2 HP EliteBook 1050 G1 SSD Replacement, SSD: 1 단계, 이미지 2/2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 SSD Replacement: 2 단계, 이미지 1/1
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
  3. HP EliteBook 1050 G1 SSD Replacement: 3 단계, 이미지 1/2 HP EliteBook 1050 G1 SSD Replacement: 3 단계, 이미지 2/2
    • With the screws removed, the SSD should pop up off of the board below.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
    • When re-inserting the new SSDs make sure the white specs labels are facing up.
결론
Elijah Holder
회원 가입일: 09/16/20
386 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 489
