주요 콘텐츠로 건너뛰기
HP EliteBook 745 G2 Cooling System Replacement
필요한 것
  1. HP EliteBook 745 G2 Cooling System Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Cooling System Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 745 G2 Cooling System Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Cooling System Replacement: 3 단계, 이미지 2개 중 1개 HP EliteBook 745 G2 Cooling System Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
  4. HP EliteBook 745 G2 Cooling System Replacement, Cooling System: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G2 Cooling System Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook 745 G2 Cooling System Replacement: 5 단계, 이미지 2개 중 2개
    • Using a Phillips #0, remove all seven of the 1.5 mm screws on the black plastic housing. Once all the screws are removed lift the plastic cover away.
    • Remove the SD card slot cover and remove the 1.5 mm Phillips #0 screw located in the slot.
  6. HP EliteBook 745 G2 Cooling System Replacement: 6 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the remaining five 1.5 mm screws holding the cooling system and fan to the motherboard.
  7. HP EliteBook 745 G2 Cooling System Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the fan and cooling system upwards until they become free from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
James Reinemann
회원 가입일: 09/18/19
532 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 19
지난 30일: 37
전체 시간: 2,159
