소개
In this guide you will be shown how to properly remove the cooling system of the HP EliteBook 745 G2. The cooling system helps keep other components of the computer cool while it is in use and prevents parts from overheating. Symptoms of a bad cooling system could include unexpected shutdowns or large amounts of heat coming from the computer. When accomplishing this replacement, it is important to disconnect the battery to ensure no damage occurs to other components.
필요한 것
Gently place the laptop down on a suitable workplace with the back of the laptop facing up
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Attach the anti-static wrist strap to any metal part of the laptop to prevent electrical damage.
다른 한 분이 해당 안내서를 완성하였습니다.
