주요 콘텐츠로 건너뛰기
HP EliteBook 745 G4 Battery Replacement
필요한 것
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: 2 단계, 이미지 1/1
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 3 단계, 이미지 1/2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 3 단계, 이미지 2/2
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: 4 단계, 이미지 1/1
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: 5 단계, 이미지 1/1
    • Loosen the two captive screws and remove the battery from the computer
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,307 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 38
전체 시간: 1,175
