주요 콘텐츠로 건너뛰기
HP EliteBook 745 G6 RAM Replacement
필요한 것
  1. HP EliteBook 745 G6 RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 RAM Replacement: 3 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 RAM Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
  5. HP EliteBook 745 G6 RAM Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 RAM Replacement: 6 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 6 단계, 이미지 2개 중 2개
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 RAM Replacement: 8 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 RAM Replacement: 9 단계, 이미지 1개 중 1개
    • Push the power button.
  10. HP EliteBook 745 G6 RAM Replacement: 10 단계, 이미지 2개 중 1개 HP EliteBook 745 G6 RAM Replacement: 10 단계, 이미지 2개 중 2개
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mengqi Shi
회원 가입일: 05/05/21
208 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 79
전체 시간: 2,778
