주요 콘텐츠로 건너뛰기
소개
Adding more memory is the best thing you can do for your PC. The larger memory can provide an instant upgrade for the system. By following this repair guide, you could add or upgrade the memory in HP EliteBook 745 G6 Notebook by yourself.
You need to pay attention to remove power, disconnect batteries, and use an anti-static wrist strap during the repair process. This is the link for how to use an anti-static wrist strap (Electrostatic Discharge & https://www.youtube.com/watch?v=qOK7X4ko...).
The Device & Model of this repair guide is HP EliteBook 745 G6 Notebook. You could find other repair guides on HP Guide Link (http://h10032.www1.hp.com/ctg/Manual/c06...).
  1. HP EliteBook 745 G6 notebook Memory Add / Upgrade, Memory: 1 단계, 이미지 1/1
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 2 단계, 이미지 1/1
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 3 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 3 단계, 이미지 2/2
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 4 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 4 단계, 이미지 2/2
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Pull the battery cable from the system board.
  5. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 5 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 5 단계, 이미지 2/2
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 6 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 6 단계, 이미지 2/2
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 7 단계, 이미지 1/1
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 8 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 8 단계, 이미지 2/2
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 9 단계, 이미지 1/1
    • Push the power button.
  10. HP EliteBook 745 G6 notebook Memory Add / Upgrade: 10 단계, 이미지 1/2 HP EliteBook 745 G6 notebook Memory Add / Upgrade: 10 단계, 이미지 2/2
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
결론
Mengqi Shi
회원 가입일: 2021년 05월 05일
181 평판
안내서 1개 작성함
York University, Team S1-G27, O'Regan Summer 2021 York University, Team S1-G27, O'Regan Summer 2021 회원
YORK-O'REGAN-SU21S1G27
1 회원
안내서 1개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 99
전체 시간: 740
