이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Adding more memory is the best thing you can do for your PC. The larger memory can provide an instant upgrade for the system. By following this repair guide, you could add or upgrade the memory in HP EliteBook 745 G6 Notebook by yourself.
You need to pay attention to remove power, disconnect batteries, and use an anti-static wrist strap during the repair process. This is the link for how to use an anti-static wrist strap (Electrostatic Discharge & https://www.youtube.com/watch?v=qOK7X4ko...).
The Device & Model of this repair guide is HP EliteBook 745 G6 Notebook. You could find other repair guides on HP Guide Link (http://h10032.www1.hp.com/ctg/Manual/c06...).
필요한 것
Type CMD in the Start Menu and open Command Prompt.
Type the following command to view memory details and press Enter.
wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor
Right-click on the taskbar.
Select the “Task Manager”.
Select the "Performance".
다른 한 분이 해당 안내서를 완성하였습니다.
