주요 콘텐츠로 건너뛰기
HP EliteBook 755 G5 Battery Replacement
필요한 것
    • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 1/2 HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 2/2
    • Turn the computer upside down on a flat surface.
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
    • Starting under the middle of the display, pry and lift the bottom cover off the computer.
  2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: 3 단계, 이미지 1/1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: 4 단계, 이미지 1/1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
회원 가입일: 04/22/20
40,298 평판
안내서 16개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,199개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 45
전체 시간: 1,080
