주요 콘텐츠로 건너뛰기
HP EliteBook 820 G3 Hard Drive Replacement
필요한 것
  1. HP EliteBook 820 G3 Hard Drive Replacement, Back Cover: 1 단계, 이미지 1/2 HP EliteBook 820 G3 Hard Drive Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Hard Drive Replacement: 2 단계, 이미지 1/2 HP EliteBook 820 G3 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/2 HP EliteBook 820 G3 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/2
    • Remove the four 3 mm screws from the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Hard Drive Replacement: 4 단계, 이미지 1/2 HP EliteBook 820 G3 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Slide the hard drive away from the system board connector to disconnect the hard drive from the system board.
    • Place it in a static dissipative bag.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Bisimwa
회원 가입일: 08/25/22
247 평판
안내서 2개 작성하였습니다
Gateway, Team 1-1, Class Fall 2022 Gateway, Team 1-1, Class Fall 2022 회원
GCC-CLASS-F22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 24
30일 전: 79
전체 시간: 1,112
