주요 콘텐츠로 건너뛰기
HP EliteBook 820 G3 Keyboard Replacement
필요한 것
  1. HP EliteBook 820 G3 Keyboard Replacement, Back Cover: 1 단계, 이미지 1/2 HP EliteBook 820 G3 Keyboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Keyboard Replacement: 2 단계, 이미지 1/2 HP EliteBook 820 G3 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 HP EliteBook 820 G3 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Keyboard Replacement: 4 단계, 이미지 1/3 HP EliteBook 820 G3 Keyboard Replacement: 4 단계, 이미지 2/3 HP EliteBook 820 G3 Keyboard Replacement: 4 단계, 이미지 3/3
    • Use an iFixit opening pick to gently pry open the top of the keyboard.
    • Gently pull the keyboard up until you can see the three ribbons under the keyboard.
  5. HP EliteBook 820 G3 Keyboard Replacement: 5 단계, 이미지 1/3 HP EliteBook 820 G3 Keyboard Replacement: 5 단계, 이미지 2/3 HP EliteBook 820 G3 Keyboard Replacement: 5 단계, 이미지 3/3
    • Lift up the latch holding down the ribbon and pull the ribbon out once it is lifted.
    • Repeat for all three of the ribbons.
    • The white ribbon (left ribbon) sometimes does not come with a new keyboard. You may need to detach it and add it to the replacement if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caleb Morales
회원 가입일: 08/25/22
127 평판
안내서 1개 작성함
Gateway, Team 1-1, Class Fall 2022 Gateway, Team 1-1, Class Fall 2022 회원
GCC-CLASS-F22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I did this, it won’t stay in.
Serial Action - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 48
전체 시간: 1,094
