주요 콘텐츠로 건너뛰기
HP EliteBook 830 G5 Battery Replacement
필요한 것
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer
    • Disconnect all external devices from the computer.
  1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 2개 중 1개 HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: 2 단계, 이미지 2개 중 2개
    • Turn the computer upside down on a flat surface.
    • Loosen the five captive screws.
    • Loosen the two inset captive screws.
    • Starting under the display, insert a case removal tool and lift the bottom cover of the computer.
  2. HP EliteBook 830 G5 Battery Replacement, Remove the battery: 3 단계, 이미지 2개 중 1개 HP EliteBook 830 G5 Battery Replacement, Remove the battery: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from the system board.
    • Remove the five Torx T8 2.5×4.0 screws.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Max Kletskov
회원 가입일: 04/22/20
40,850 평판
안내서 16개를 작성함
The Home Depot The Home Depot 회원
Community
18,092 회원들
안내서 140개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 137
전체 시간: 3,340
