주요 콘텐츠로 건너뛰기
HP EliteBook 840 Aero G8 Motherboard Replacement
필요한 것
  1. HP EliteBook 840 Aero G8 Motherboard Replacement, Speakers: 1 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement, Speakers: 1 단계, 이미지 2/2
    • Turn the laptop upside-down.
    • Remove all five of the 4.48mm housing screws using a Philips #0 screwdriver.
    • Remove the cover using an iFixit opening tool.
  2. HP EliteBook 840 Aero G8 Motherboard Replacement: 2 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the iFixit opening tool, remove the right-hand side speaker.
    • Using the iFixit opening tool, remove the left-hand side speaker.
  3. HP EliteBook 840 Aero G8 Motherboard Replacement: 3 단계, 이미지 1/3 HP EliteBook 840 Aero G8 Motherboard Replacement: 3 단계, 이미지 2/3 HP EliteBook 840 Aero G8 Motherboard Replacement: 3 단계, 이미지 3/3
    • Using the plastic spudger, disconnect the speaker power cable.
    • Remove the wire from the device apparatus until it is fully isolated. The speaker system can now be removed from the computer to fix or replace as needed.
  4. HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 HP EliteBook 840 Aero G8 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Using the spudger, unplug the battery from the motherboard.
    • Use the PH1 screwdriver to remove the screws from the battery.
    • Set aside the four 4.48mm screws.
    • Remove the battery from the casing.
  5. HP EliteBook 840 Aero G8 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using the spudger, gently unplug the RTC battery from the motherboard.
  6. HP EliteBook 840 Aero G8 Motherboard Replacement: 6 단계, 이미지 1/3 HP EliteBook 840 Aero G8 Motherboard Replacement: 6 단계, 이미지 2/3 HP EliteBook 840 Aero G8 Motherboard Replacement: 6 단계, 이미지 3/3
    • Using the spudger, unplug the fan power cable from the motherboard.
    • Use the PH1 screwdriver to remove the three 4.48 mm screws.
    • Remove the fan from the computer.
  7. HP EliteBook 840 Aero G8 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the PH1 screwdriver to unscrew the heat sink from the motherboard.
    • Remove the heat sink from the computer.
  8. HP EliteBook 840 Aero G8 Motherboard Replacement: 8 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use ESD-safe tweezers to disconnect the display cables from the WAN module.
    • Using a spudger, disconnect the display power cable from the motherboard.
  9. HP EliteBook 840 Aero G8 Motherboard Replacement: 9 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement: 9 단계, 이미지 2/2
    • Use a PH1 screwdriver to remove the 4.48 mm screw that secures the WAN card on the left side of the motherboard.
    • Use a PH1 screwdriver to remove the 4.48 mm screw that secures the WLAN card located on the right side of the motherboard.
  10. HP EliteBook 840 Aero G8 Motherboard Replacement: 10 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement: 10 단계, 이미지 2/2
    • Using the iFixit opening tool, disconnect the camera power cable on the left hand side of the motherboard.
    • Using the iFixit opening tool, disconnect the camera connection cable from the right-hand side of the motherboard.
  11. HP EliteBook 840 Aero G8 Motherboard Replacement: 11 단계, 이미지 1/1
    • Using a PH1 screwdriver, remove the bracket holding the left side of the motherboard in place. These four screws are the longer of the two types of screws found in this laptop, measuring 4.48mm in length.
  12. HP EliteBook 840 Aero G8 Motherboard Replacement: 12 단계, 이미지 1/1
    • Using the iFixit opening tool, unplug the USB board from the motherboard.
  13. HP EliteBook 840 Aero G8 Motherboard Replacement: 13 단계, 이미지 1/1
    • Using the iFixit opening tool, unplug the fingerprint reader from the motherboard.
  14. HP EliteBook 840 Aero G8 Motherboard Replacement: 14 단계, 이미지 1/1
    • Using the iFixit opening tool, unplug the NFC module from the motherboard.
  15. HP EliteBook 840 Aero G8 Motherboard Replacement: 15 단계, 이미지 1/1
    • Using the iFixit opening tool, disconnect the click button assembly from the motherboard.
  16. HP EliteBook 840 Aero G8 Motherboard Replacement: 16 단계, 이미지 1/1
    • Using the iFixit opening tool, disconnect the touchpad from the motherboard.
  17. HP EliteBook 840 Aero G8 Motherboard Replacement: 17 단계, 이미지 1/1
    • Using tweezers, gently pull on the smart card reader board to disconnect it from the motherboard.
  18. HP EliteBook 840 Aero G8 Motherboard Replacement: 18 단계, 이미지 1/1
    • Using the iFixit opening tool, disconnect the motherboard's power cable.
  19. HP EliteBook 840 Aero G8 Motherboard Replacement: 19 단계, 이미지 1/2 HP EliteBook 840 Aero G8 Motherboard Replacement: 19 단계, 이미지 2/2
    • Use the PH1 screwdriver to remove the two 4.48mm screws from the motherboard.
    • Use the PH1 screwdriver to remove the three 2.52mm screws from the motherboard.
    • You can now remove the motherboard from the computer to replace or fix it, as needed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Riley Rustman
회원 가입일: 11/09/23
499 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-2, Harley Fall 2023 IUPUI, Team 2-2, Harley Fall 2023 회원
IUPUI-HARLEY-F23S2G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 62
전체 시간: 279
