필요한 것
As always:
Unplug the power cord, turn off and remove the battery.
Turn the notebook over and remove the Gimmi covers with a small screwdriver.
Now unscrew all 9! screws (see arrow) and carefully loosen the lower shell.
Now install the new M.2 SSD and fasten it with the small screw (arrow).
Now plug the new hard drive into the appropriate connector.
Tighten the two screws.
Close the notebook with the bottom shell and make sure that everything clicks into place nicely.
Screw everything back together and press the small rubber covers tight.
Insert the battery.
Turn on the device.
Reinstall Windows or format the new hard drive if you installed it as an add-on hard drive.
Work the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
