주요 콘텐츠로 건너뛰기
HP EliteBook 840 G5 Trackpad Assembly Replacement
필요한 것
  1. HP EliteBook 840 G5 Trackpad Assembly Replacement, Back Cover: 1 단계, 이미지 1/2 HP EliteBook 840 G5 Trackpad Assembly Replacement, Back Cover: 1 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
    • Unscrew the bottom three screws using the same screwdriver.
    • The bottom Phillips #1 screws don't remove from the back plate, but do need to be unscrewed.
    • Some models have a slightly different screw configuration, shown in the second photo.
  2. HP EliteBook 840 G5 Trackpad Assembly Replacement: 2 단계, 이미지 1/3 HP EliteBook 840 G5 Trackpad Assembly Replacement: 2 단계, 이미지 2/3 HP EliteBook 840 G5 Trackpad Assembly Replacement: 2 단계, 이미지 3/3
    • Turn computer so that the hinged side is facing up.
    • Use the plastic opening tool to pry open the back plate.
    • Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
    • Repeat the 3rd step for the other side.
    • Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
    • You should be able to hear a pop when prying open the corners.
  3. HP EliteBook 840 G5 Trackpad Assembly Replacement: 3 단계, 이미지 1/1
    • Grab the back plate and separate it slowly away from the device.
    • No wiring is connected to the back plate. Separate with caution, as there are electric components on the inside.
  4. HP EliteBook 840 G5 Trackpad Assembly Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the 4mm screws that are fastened on the battery with your T9 Torx screwdriver.
  5. HP EliteBook 840 G5 Trackpad Assembly Replacement: 5 단계, 이미지 1/2 HP EliteBook 840 G5 Trackpad Assembly Replacement: 5 단계, 이미지 2/2
    • Carefully remove the power supply connector by tugging it from the sides of its head.
    • Make sure not to pull on the wires, as they could become damaged.
  6. HP EliteBook 840 G5 Trackpad Assembly Replacement: 6 단계, 이미지 1/1
    • Slide the battery out and remove it from the device.
  7. HP EliteBook 840 G5 Trackpad Assembly Replacement, Trackpad Assembly: 7 단계, 이미지 1/2 HP EliteBook 840 G5 Trackpad Assembly Replacement, Trackpad Assembly: 7 단계, 이미지 2/2
    • The underside of the track pad should become apparent after battery removal. It is covered by a protective layer of mint green colored foam.
    • Using the Phillips #1 screwdriver, unscrew the five 2 mm long screws which are along the side of the track pad.
  8. HP EliteBook 840 G5 Trackpad Assembly Replacement: 8 단계, 이미지 1/3 HP EliteBook 840 G5 Trackpad Assembly Replacement: 8 단계, 이미지 2/3 HP EliteBook 840 G5 Trackpad Assembly Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift up on the connector gate with a pair of precision tweezers, which clamps down on the end of the ribbon cable.
    • In the second picture, the foam is pulled back for clarity.
    • With the pair of tweezers, firmly clamp down on the ribbon cable, and pull it away from the connector gate.
  9. HP EliteBook 840 G5 Trackpad Assembly Replacement: 9 단계, 이미지 1/2 HP EliteBook 840 G5 Trackpad Assembly Replacement: 9 단계, 이미지 2/2
    • Lift up on the second connector gate with a pair of precision tweezers.
    • Use the tweezers to pull the Ribbon Cable away from the second connector gate.
  10. HP EliteBook 840 G5 Trackpad Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the track pad.
    • Be sure to pull out carefully. If the computer is closed, the screen will be exposed underneath the track pad.
  11. HP EliteBook 840 G5 Trackpad Assembly Replacement: 11 단계, 이미지 1/1
    • After lifting the connector gate with the precision tweezers, gently pull on the ribbon cable that connects the clickers to the motherboard.
  12. HP EliteBook 840 G5 Trackpad Assembly Replacement: 12 단계, 이미지 1/2 HP EliteBook 840 G5 Trackpad Assembly Replacement: 12 단계, 이미지 2/2
    • Using your Phillips #1 screwdriver, remove the 3mm long screws on the underside of the track pad's clicker.
    • Make sure to move any ribbon cables back to ensure clear view of screws.
    • Pull the clicker out of the computer.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Lucas Martos-Repath
회원 가입일: 04/23/18
774 평판
안내서 3개 작성하였습니다
Cal Poly, Team S25-G13, Maness Spring 2018 Cal Poly, Team S25-G13, Maness Spring 2018 회원
CPSU-MANESS-S18S25G13
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 75
전체 시간: 4,631
