주요 콘텐츠로 건너뛰기
HP EliteBook 840 G7 keyboard Replacement
필요한 것
  1. HP EliteBook 840 G7 keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 keyboard Replacement: 2 단계, 이미지 1/1
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 keyboard Replacement: 4 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 4 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 4 단계, 이미지 3/3
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 keyboard Replacement: 5 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 5 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 5 단계, 이미지 3/3
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 keyboard Replacement, Display Assembly: 6 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement, Display Assembly: 6 단계, 이미지 2/2
    • Pull up to remove the two coaxial Wi-Fi card connectors.
  7. HP EliteBook 840 G7 keyboard Replacement: 7 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 7 단계, 이미지 2/2
    • Pull upwards on the display connector to remove.
  8. HP EliteBook 840 G7 keyboard Replacement: 8 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 8 단계, 이미지 2/2
    • Pull or push to remove the bundled cable connector.
  9. HP EliteBook 840 G7 keyboard Replacement: 9 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 9 단계, 이미지 2/2
    • Pull upwards to remove the webcam connector.
  10. HP EliteBook 840 G7 keyboard Replacement: 10 단계, 이미지 1/1
    • Once you've disconnected all cables from their sockets, gently move them to the top of the laptop.
  11. HP EliteBook 840 G7 keyboard Replacement: 11 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 11 단계, 이미지 2/2
    • Use your Phillips # 1 screwdriver to remove the four 1.2 mm screws.
  12. HP EliteBook 840 G7 keyboard Replacement: 12 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 12 단계, 이미지 2/2
    • Use your Phillips # 1 screwdriver to remove the two 1.2mm screws.
  13. HP EliteBook 840 G7 keyboard Replacement: 13 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 13 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 13 단계, 이미지 3/3
    • Open the laptop to a 90 degree angle.
    • Slide the display hinges away to remove the display assembly.
  14. HP EliteBook 840 G7 keyboard Replacement, Keyboard: 14 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: 14 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement, Keyboard: 14 단계, 이미지 3/3
    • Pull on the bundled connector to remove.
    • Remove the speaker system from the board.
  15. HP EliteBook 840 G7 keyboard Replacement: 15 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 15 단계, 이미지 2/2
    • Push away to remove the bundled connector from its port.
    • Move the cable away from the ZIF connector below.
  16. HP EliteBook 840 G7 keyboard Replacement: 16 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 16 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 16 단계, 이미지 3/3
    • Lift the latch on the ZIF connector.
    • Pull away on the connector to remove.
  17. HP EliteBook 840 G7 keyboard Replacement: 17 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 17 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 17 단계, 이미지 3/3
    • Use your Phillips #1 screwdriver to remove the three 1.3 mm screws.
    • Lift up and away to remove the USB ports.
  18. HP EliteBook 840 G7 keyboard Replacement: 18 단계, 이미지 1/2 HP EliteBook 840 G7 keyboard Replacement: 18 단계, 이미지 2/2
    • Push away to remove the bundled connector.
  19. HP EliteBook 840 G7 keyboard Replacement: 19 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 19 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 19 단계, 이미지 3/3
    • Use your Phillips # 1 screwdriver to remove the three 1.2 mm screws that hold the fan in place.
    • Lift up from the left side of the fan then pull towards you to remove.
  20. HP EliteBook 840 G7 keyboard Replacement: 20 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 20 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 20 단계, 이미지 3/3
    • After removing the connector pull off the CMOS battery.
  21. HP EliteBook 840 G7 keyboard Replacement: 21 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 21 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 21 단계, 이미지 3/3
    • Use your Phillips #1 screwdriver to remove the single 1.2 mm screw.
    • Pull on the cable to remove the charging port.
  22. HP EliteBook 840 G7 keyboard Replacement: 22 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 22 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 22 단계, 이미지 3/3
    • Lift on the latch on the ZIF connector.
    • Pull on the cable to remove.
  23. HP EliteBook 840 G7 keyboard Replacement: 23 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 23 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 23 단계, 이미지 3/3
    • Release the latch on the ZIF connector.
    • Carefully pull the connector to remove.
  24. HP EliteBook 840 G7 keyboard Replacement: 24 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 24 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 24 단계, 이미지 3/3
    • Use you Phillips #1 screwdriver to remove the eight 1.2 mm screws.
    • Lift the whole board up to remove.
  25. HP EliteBook 840 G7 keyboard Replacement: 25 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 25 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 25 단계, 이미지 3/3
  26. HP EliteBook 840 G7 keyboard Replacement: 26 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 26 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 26 단계, 이미지 3/3
  27. HP EliteBook 840 G7 keyboard Replacement: 27 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 27 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 27 단계, 이미지 3/3
    • Use your Phillips #000 screwdriver to remove the four 1 mm screws.
    • Pull up to remove.
    • Careful to not harm other cables.
  28. HP EliteBook 840 G7 keyboard Replacement: 28 단계, 이미지 1/3 HP EliteBook 840 G7 keyboard Replacement: 28 단계, 이미지 2/3 HP EliteBook 840 G7 keyboard Replacement: 28 단계, 이미지 3/3
    • Use your Phillips #000 screwdriver to remove the five 1 mm screws.
    • Lift the touchpad to remove.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Pedro Ramos Espinoza
회원 가입일: 02/10/22
790 평판
안내서 4개 작성하였습니다
Gateway, Team 1-1, Pee Spring 2022 Gateway, Team 1-1, Pee Spring 2022 회원
GCC-PEE-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Donc ce tuto permet de tout enlever sauf le clavier?
Pilc - 답글
This is only replacement of the touchpad?
Where is the keyboard replacement?
Koehoe22 - 답글
the keyboard is part of the top shell and is rivetted in, you need to replace the whole part
Leonardo Di Stefano -
댓글 쓰기
조회 통계:
24 시간 전: 27
7일 전: 103
30일 전: 471
전체 시간: 10,586
