주요 콘텐츠로 건너뛰기
HP EliteBook 845 G8 Thermal Paste Replacement
필요한 것
  1. HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: 1 단계, 이미지 3개 중 1개 HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: 1 단계, 이미지 3개 중 2개 HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: 1 단계, 이미지 3개 중 3개
    • Remove the 5 screws holding the back panel.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: 2 단계, 이미지 3개 중 1개 HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: 2 단계, 이미지 3개 중 2개 HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: 2 단계, 이미지 3개 중 3개
    • Unscrew the 4 screws holding the CPU heatsink and lift it up, gently.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  3. HP EliteBook 845 G8 Thermal Paste Replacement, Applying new thermal paste.: 3 단계, 이미지 1개 중 1개
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
  4. HP EliteBook 845 G8 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): 4 단계, 이미지 1개 중 1개
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want. Just carefully lift up the metal shields and replace them.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Simeon Brankov
회원 가입일: 11/08/20
7,180 평판
안내서 54개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 181
전체 시간: 2,884
