주요 콘텐츠로 건너뛰기
HP EliteBook 8530w Battery Replacement
  1. HP EliteBook 8530w Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP EliteBook 8530w Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Battery Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 8530w Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 653
