주요 콘텐츠로 건너뛰기
HP EliteBook 8560w Back Panel Replacement
필요한 것
  1. HP EliteBook 8560w Back Panel Replacement, Battery: 1 단계, 이미지 1/2 HP EliteBook 8560w Back Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: 2 단계, 이미지 1/1
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: 3 단계, 이미지 1/2 HP EliteBook 8560w Back Panel Replacement, Back Panel: 3 단계, 이미지 2/2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: 4 단계, 이미지 1/1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
결승점
Alexandre Mota
회원 가입일: 01/14/20
456 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 21
전체 시간: 1,420
