주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Fan Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Fan Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Fan Replacement, Fan: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  4. HP EliteBook x360 1030 G3 Fan Replacement: 4 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Fan Replacement: 4 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Fan Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Pablo Arriola
회원 가입일: 04/22/19
528 평판
안내서 3개를 작성함
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 54
전체 시간: 4,807
