주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Solid State Drive Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 2개 중 2개
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Pablo Arriola
회원 가입일: 04/22/19
543 평판
안내서 3개를 작성함
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 17개를 작성함
3가이드 댓글
Which SSD is compatible with this computer?
Trinayaan Hariharan - 답글
Very nice its clear
Fuad Gugsa - 답글
J'ai un problème de son
Sallpape - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 111
전체 시간: 7,822
