주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Solid State Drive Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 2 단계, 이미지 1/1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 1/2 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 2/2
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 4 단계, 이미지 1/1
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: 5 단계, 이미지 1/1
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Pablo Arriola
회원 가입일: 04/22/19
504 평판
안내서 3개 작성하였습니다
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개 작성하였습니다
댓글 3개
Which SSD is compatible with this computer?
Trinayaan Hariharan - 답글
Very nice its clear
Fuad Gugsa - 답글
J'ai un problème de son
Sallpape - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 34
30일 전: 119
전체 시간: 5,991
