주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Speakers Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Speakers Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Speakers Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Speakers Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Speakers Replacement, Touchpad: 6 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement, Touchpad: 6 단계, 이미지 2개 중 2개
    • Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
  7. HP EliteBook x360 1030 G3 Speakers Replacement: 7 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement: 7 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Speakers Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the small white ZIF connector from the front using a spudger tool or your finger.
    • Only lift the white hinge securing the Flexed Flat Cable making sure the unit stays secure to the board.
  8. HP EliteBook x360 1030 G3 Speakers Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the yellow and orange striped ribbon away.
  9. HP EliteBook x360 1030 G3 Speakers Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the touchpad up from the computer board by the metal frame.
  10. HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: 10 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: 10 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Speakers Replacement, Speakers: 10 단계, 이미지 3개 중 3개
    • Remove the two 3.52 mm JIS #000 screws from the left speaker.
    • The speakers are magnetic, so carefully remove from its magnetic place.
  11. HP EliteBook x360 1030 G3 Speakers Replacement: 11 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement: 11 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Speakers Replacement: 11 단계, 이미지 3개 중 3개
    • Follow the red and black wire and you will see the two wire brackets.
    • Use the spudger to slide it and push the wire out of the brackets, then take it out.
  12. HP EliteBook x360 1030 G3 Speakers Replacement: 12 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement: 12 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Speakers Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the two 3.52 mm JIS #000 screws from the right speaker and carefully remove from its magnetic place.
    • Remove the black tape with your hand that is around wire.
  13. HP EliteBook x360 1030 G3 Speakers Replacement: 13 단계, 이미지 3개 중 1개 HP EliteBook x360 1030 G3 Speakers Replacement: 13 단계, 이미지 3개 중 2개 HP EliteBook x360 1030 G3 Speakers Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the black tape from the mother board with your hand.
    • Unplug the green and white wire plug gently, and the red and black wire plug gently with your hand.
결론
작성자
1다른 기여자 명과 함께
Mahn Hein Ko
회원 가입일: 05/17/22
109 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 654
